Disaster Recovery Executable File
A Disaster Recovery executable file has been developed for Administrators who want to configure and edit their disaster recovery settings by using a scripting language.
The Disaster Recovery executable file is named drconfig.exe and is located in the following folder.
…./Program Files (x86)/Upland AccuRoute/AccuRoute/Bin
The executable file allows Administrators to perform the following tasks at the Command line without the use of the Server Administrator.
Before you begin
The drconfig.exe file can be used to print component names, set primary and backup site values, retrieve configuration details or initiate cutover only after Disaster Recovery is configured in the Server Administrator.
  • Set up Disaster Recovery using the Server Administrator.
  • If Disaster Recovery is currently set up via the Server Administrator, open the Disaster Recovery settings in the Server Administrator and select OK to save the settings without making any changes. This ensures that each Disaster Recovery component is given a unique name which is required for scripting.
See the Server Administrator > Disaster Recovery Settings dialog box example below.
server administrator disaster recovery settings dialog box
Accessing the Disaster Recovery executable file
Any application created to call the drconfig.exe file must be able to find and run it from the Bin folder on the server. You cannot copy the executable file to a different folder. It will not work properly.
Optional Configurations - Disaster Recovery Solution
