Removing the Print Option
The Relationship Map print option (highlighted below) can be removed from your org's insight maps if required.
To remove the print option, do the following:
  1. In Setup, go to Custom Settings.
  2. Click Manage beside Altify Core Settings.
  3. Click Edit.
  4. Select the Disable Print Buttons [Temp5] check box.
  5. Click Save.
Note: This setting also disables the option to print insight maps.
