To Populate Your Index, Run a Target Job
Run a Full Target Update
After you add a Target, you must run a Full Target Update job to populate your search index.
After a Full Target Update job is successfully run, you update your Target with (typically scheduled) Incremental Target Update jobs.
To run a Full Target Update job, follow these steps:
- Go to the Connectivity Hub Tasks page.
- Click New and the Edit Job page appears.
- In the Scope drop-down list, select the Content Source for which you want to run a Full Target Update.
- Select "Target Full Update" in the Job drop-down list. Other options are listed below:
- Target Incremental Update: Select to update only the indexed items that have changed since previous target sync.
- Target Content Reset: Select to remove the indexed data while leaving the content source that is attached to the data unchanged.
- Schedule (Required): Select using the drop down:
- One Time: Runs the task now.
- Scheduled: Specify a simplified/advanced schedule for your target job.
Log level
Required
Default:
Warn -
Alternatively, use the drop-down to select:
Error -
Info -
Trace
Any change that you make overrides the log level for a job.
The job logs are stored in the configuration database, so use
InfoorTracelevels for testing purposes only. -
- Alert recipients:
- Enter an email list of people to notify if there is an error.
- This list must be separated using semicolons (
;). - Do not forget to configure the email server and address in Connectivity Hub. (Tools > Configuration > Smtp Server)
- Create: Click "Create" to start your job and see the results in Active Jobs:
- (To resolve issues)
> Edit > View Logs: See the logs for the target job(s) that you ran.
