About the Contentful Connector
Features
- Enables searching for Entries stored in a Contentful space.
- Content to be indexed can be filtered by Content Type
- All content remains in the space.
Security
The Connector only returns Published Entries. All items indexed will be marked as Public.
Limitations
- Only Published items are returned.
- Location field values are returned as coordinates
- Entry comments are not retrieved
- The escabase_url metadata displays the source system URL and not the Contentful Preview URL.
- Because the Preview URL is highly customizable in Contentful we recommend using scripting to generate the URL metadata to match the Preview URL using a base URL and metadata.
Metadata
All fields added in the Content Model are returned as metadata.
You must run a Datastore Types Load task to pick up changes made to the Content Model.
| Metadata property | Value Type | Description |
| ID | String | The ID of the Entry |
| ContentType | String | The Content Type of the Entry |
| Tags | String multi value | Tags assigned to an Entry |
| Title | String | The value of the field assigned as the Title Field for the Content Type |
