About the Microsoft Teams Connector
The Teams connector allows you to index Teams content with security.
It supports all standard connectors capabilities:
Incremental/full crawls
Security
Metadata
Features
The BA Insight Microsoft Teams connector:
- Supports all versions of Teams
- Searchable content types
- Teams
- Channels
- Conversations
- Content update
- Full and incremental crawls
Security
Search behavior matches the behavior in Microsoft Teams.
- Conversions and Channels in public teams are only returned for members of the team
- Conversations and Channels for Organization-wide teams are returned for all search users.
Limitations
- Files, wikis, or OneNote documents stored in SharePoint Online team sites are not indexed via this connector, you must deploy the SharePoint Online connector instead
- Personal chats are not supported
- External users are not supported.
- Teams includes external users are only secured based on internal users only*****
- Extensions (such as interacting with a Box account) are not supported
- In some cases, soft deletes and hard deletes are not fully supported due to Microsoft Teams API limitations.
- Users will see the item as deleted in Teams and the API reports it as if it was not deleted.
Metadata
Metadata properties supported by the connector are listed below (grouped by content types).
The fileextension property is set as "html" for Conversations and left blank for Teams and Channels.
If these need to be indexed, the target in Connectivity Hub must be configured accordingly.
If these need to be indexed, the target in CH must be configured accordingly.
Teams
| Metadata Property | Value Type | Description |
| SPW_TITLE | String | The display name for the team. Matches displayName property of the team's group resource type. |
| SPW_URL | String | A hyperlink that will go to the team in the Microsoft Teams client. Matches webUrl property of the team resource type. |
| dataStoreTypeID | String | An identifier for the content type. Always contains TEAM_CONTENT_TYPE static value. |
| dataStoreTypeName | String | A display name for the content type. Always contains Team static value. |
| createdDateTime | DateTime | Timestamp of when the team was created. Matches createdDateTime property of the team's group resource type. |
| description | String | An optional description for the team. Matches description property of the team's group resource type. |
| internalId | String | Matches internalId property of the team resource type. |
| isArchived | Boolean | Matches isArchived property of the team resource type. |
| allowCustomMemes | Boolean | Matches teamFunSettings.allowCustomMemes property of the team resource type. |
| allowGiphy | Boolean | Matches teamFunSettings.allowGiphyproperty of the team resource type. |
| allowStickersAndMemes | Boolean | Matches teamFunSettings.allowStickersAndMemes property of the team resource type. |
| giphyContentRating | String | Matches teamFunSettings.giphyContentRating property of the team resource type. |
| visibility | String | Matches visibility property of the team's group resource type. |
Channels
| SPW_TITLE | String | Channel name as it will appear to the user in Microsoft Teams. Matches displayName property of the channel resource type. |
| SPW_URL | String | A hyperlink that will navigate to the channel in Microsoft Teams. Matches webUrl property of the channel resource type. |
| dataStoreTypeID | String | An identifier for the content type. Always contains CHANNEL_CONTENT_TYPE static value. |
| dataStoreTypeName | String | A display name for the content type. Always contains Team Channel static value. |
Optional textual description for the channel. Matches description property of the channel resource type. |
| String | Matches email property of the channel resource type. |
Conversations
A title of channel message in the following format: Message from {from} on {createdDateTime}
where from and createdDateTime are replaced with the corresponding metadata properties of the message. If a message has non-empty subject property, then the title has the following format: Message from {from} on {createdDateTime} ({subject})
| SPW_URL | String | A hyperlink that will navigate to the channel message in Microsoft Teams. Matches webUrl property of the chatMessage resource type. |
| dataStoreTypeID | String | An identifier for the content type. Always contains MESSAGE_CONTENT_TYPE static value. |
| dataStoreTypeName | String | A display name for the content type. Always contains Channel Message static value. |
| from | String |
Display name of the sender of the chat message. Matches displayName part of from property of the chatMessage resource type. |
messageType |
String | Matches messageType property of the chatMessage resource type. |
| createdDateTime | DateTime | Timestamp of when the chat message was created. Matches createdDateTime property of the chatMessage resource type. |
subject |
String | The subject of the chat message, in plaintext. Matches subject property of the chatMessage resource type. |
summary |
String | Summary text of the chat message that could be used for push notifications and summary views or fall back views. Matches summary property of the chatMessage resource type. |
importance |
String | The importance of the chat message. Matches importance property of the chatMessage resource type. |
locale |
String |
Locale of the channel message set by the client. Matches locale property of the chatMessage resource type. |
attachmentsJson |
String | A raw JSON representation of attachments property of the chatMessage resource type (defined by chatMessageAttachment resource type). |
