About the OneDrive Connector
Overview
The BA Insight OneDrive Connector makes it possible to index content from OneDrive into Azure, SharePoint Online or the SharePoint 2016/2013 index and surface it through BA Insight’s SmartHub, providing users with integrated search results from multiple sources.
A single consolidated search index referencing OneDrive, along with content from other repositories, is surfaced as a single unified result set, giving users a single access point for searching across the enterprise.
For more information about the OneDrive connector features and abilities, see https://www.bainsight.com/connectors/onedrive-business-connector-sharepoint-azure-elasticsearch/.
Metadata
The default behavior of the OneDrive Connector is to not include 'hidden' properties in the metadata returned for the items.
However, this can be customized by specificing a list of 'hidden' properties (in the web.config configuration file) to be returned by the search engine.
