About the Oracle Web Center Content Connector
Note: The Oracle Web Center Content connector was previously known as the "Oracle Stellent UCM" connector.
The Oracle Web Center connector enables you to extract content and security from your Oracle CM System for searching and migration.
This Connector uses both direct database calls and the Oracle CM web service API to index your data.
The reason for this dual connection is scaling:
By enumerating data directly from the database, you can index larger sets of data and rapidly check for changes.
In Stellent, security can be based on a user belonging to both a group and account.
This dynamic security model is not supported in AD.
The Connector expands all of the possible combinations of groups and accounts into new groups that are tracked with crawls.
When either an account or a group membership changes, only the affected documents change.
This document is focused on the specifics of the Oracle Web Center Content Connector and does not cover generic or common steps.
For more information, see Upland BA Insight Connectivity Hub v2.2 .
