About the iManage Connector
The iManage connector is a web-service connector that enables you to index iManage content with security.
It supports all standard connector capabilities:
  • Incremental and Full crawls
  • Security
  • Metadata
Features
  • Enables searching for any kind of document stored in iManage.
  • Operates with minimal impact on iManage.
    • Once content is crawled, all search activity takes place in SharePoint, or any other portal.
  • Provides high performance indexing, so large amounts of content can be made available to users.
  • Leverages iManage security to determine which documents users can access.
  • All content remains safely in iManage.
    • The portal has only a searchable representation of documents – pointers – and users are directed back to iManage to launch documents found in their search result.
Limitations
Tenant Instance Support
  • Instances of *.imanage.work tenants are NOT supported.
  • Instances of cloudimanage.com tenants are supported.
Note: Start date setting on content settings page is not supported.
Note: A full crawl is required whenever the last incremental crawl/ full crawl was started more than 2 weeks ago.
Security
See iManage Connector Security.
