Azure Blob Connector Prerequisites
Required Permission Description
Azure The installation user account must be able to register, configure, and grant Access for an Azure application.
Azure App Permissions
The application configured for the connector must have the following Graph API permissions granted in Microsoft Azure:
Note: The type for the following permissions must be "Application".
Delegated permissions are not required.
  • Directory.Read.All
  • GroupMember.Read.All
  • Member.Read.Hidden
  • User.Read.All
Azure Blob Storage
Multiple Permissions
The application configured for the connector must be granted the following permissions (otherwise use the "Single Role" detailed below):
  • Microsoft.Storage/storageAccounts/read
  • Microsoft.Storage/storageAccounts/blobServices/read
  • Microsoft.Storage/storageAccounts/blobServices/generateUserDelegationKey/action
  • Microsoft.Storage/storageAccounts/blobServices/containers/read
  • Microsoft.Storage/storageAccounts/blobServices/containers/blobs/tags/read
  • Microsoft.Storage/storageAccounts/blobServices/containers/blobs/read
  • Microsoft.Storage/storageAccounts/blobServices/containers/blobs/filter/action
This can be achieved by creating a custom role in Azure (see Microsoft documentation) and assigning it to your configured application.
Single Role
Alternatively, for a faster implementation, assign your application the Storage BlobData Owner role.
These are the minimal permissions (or role) necessary to properly extract and report metadata and security/ACLs on the blobs indexed.
Windows  The account used to run the connector must be a local Administrator on the server and cannot be any of the built-in service accounts (NetworkService, local machine, etc.)
Features Supported Additional Information
Searchable content types Yes All content types.
Content Update Full and Incremental All BA Insight Connectors support both Full and Incremental crawls, unless noted.
Permission Types Yes
All BA Insight Connectors support fetch ACLs from the source system.
To make items public or restricted to a single user/set of users, you can do so within the Connector Framework.
Required Software
IIS
.NET Framework v4.7.2
ASP.Net must be enabled
Connectivity Hub Version v2.2 or newer Azure Blob Connector requires Connectivity Hub version 2.2 or newer in order for all features to work properly.
