Configure Egnyte Web Site IIS Certificate
  1. Open the IIS manager and confirm your Egnyte IIS site exists:
  2. Bind your web server certificate to the newly-created site:
    1. Locate the entry BA Insight Egnyte Connector site in the left-side pane.
    2. Right-click this site and select Edit Bindings from the sub-menu that appears.
    3. A new configuration windows opens.
      Port: Ensure that the Port (443) has been populated by the installer. See the graphic below.
    4. SSL certificate: Click the drop-down menu to select your previously installed certificate.
      See the Edit Site Binding window.
  3. If running on a specific hostname or running multiple Certificates on Port 443 specify or select the:
    1. Host name
    2. Require Server Name Indication
    3. SSL certificate
    4. Access to this example site would be "https://autoclassifier.baitest.local"
      Example
  4. ClickOKto complete the configuration process.
  5. Optional:If the HTTP binding is no longer used, it can be removed. Select the configuration binding and click "Remove."
