How to Configure Your Jira Connector Using Web.config
Like all BA Insight connectors, the Jira connector has a web.config file that can be used to make specific, advanced modifications to your connector.
Modify your connector's web.config file only when necessary.
This file does not contain settings that are commonly changed. Make changes to this file with caution.
Location of Web.config File
The web.config file is located at <ConnectorRoot>\WebService\Web.config.
Web.config File Details
The Jira connector web.config file is shown below.
The application settings can be found around line 63.
