How to Configure the ServiceNow Connector Using Web.config
The web.config file is found at the root level of every BA Insight connector's installation directory.
CAUTION! The file web.config contains settings that are not commonly changed. Make changes to this file with caution.
Inactive Incidents
The ServiceNow connector can crawl inactive incidents.
To activate this option, set the "CrawlInactiveIncidents" value in the file web.config to true:
<add key="CrawlInactiveIncidents" value="true" />
Paging Size
The ServiceNow connector paging size can be manually adjusted.
To adjust the ServiceNow connector paging size set the following values in the file web.config:
  • User Security Fields
    • To return additional user fields during security sync add values to the pre-configured list.
      <add key="UserSecurityFields" value="name,employee_number,user_name,sys_id,first_name,email,last_name,middle_name,user_name,active"/>
  • MarkMultiLevelDocuments
    • To enable Multi-Level documents set this value to true.
      <add key="MarkMultiLevelDocuments" value="true" />
  • RequestedItemsPerQuery
    • This value controls the paging size for Security Map and Retrieving Item details.
    • Adjust this value based on individual performance.
    • Request items per query:
      • Default: 500
    • Maximum Requested Items per query: 10,000
      <add key="RequestedItemsPerQuery" value="500" />
  • EnumerationItemsPerQuery
    • This value controls the paging size for Full and Incremental enumeration.
    • Adjust the value based on individual performance.
    • The enumeration request items per query defaults to 5000
    • Maximum Requested Items per enumeration query: 10,000
      <add key="EnumerationItemsPerQuery" value="5000" />
