Create a Self-Signed Certificate
If you are using a X.509 Certificate from a Certificate Authority skip to the next section: Configure Your Site to Use Certificates.
To use the Self-Signed High Trust Certificate Generation Page the Site App Pool Account must be a local Admin to allow access to the Certificate Store.  Once created the requirement can be removed.
Note: Issued To
When using the Server Name as the Issued To value you will often recieve a Certificate Name mis-match warning in the Web Browers even if the Add-In Site has been Added as a Trusted Site.  This warning does NOT impact functionality.
If a DNS record can be added depending on company policy, this mis-match warning can be avoided by using the Add-In Web Site Host Name.
Example:  Add-In Web Site Host Name:  Issued To:  addin.mydomain.local
Add a DNS entry addin.mydomain.local pointing to the server ip adress.
Procedure:
  1. Navigate to the Self-Signed High Trust Certificate Generation page.
    Example:http://localhost:5062/Pages/Certificate.aspx
  2. Enter the following fields
    1. Certificate Friendly Name:  Enter a friendly name for the Certificate. Default: BAInsight AutoClassifier AddIn
    2. Issued To: Enter Issued To.  Default: The default value is set to the server FDQN.
      See Note below regarding using Issued To.
    3. Years of Validity:  Enter number of years in which the certificate will expire.
    4. Password:  Enter the certificate password.  **AutoClassifier does not store this password therefore store the password in a safe location for future use.
  3. Click the Generate Certificate button.
    A certicate is generated and loaded to both the Personal and Trusted Root Certification Authorities certificate stores.
  4. Once generated, the same certificate can NOT be regenerated without first being removed from the Certificate Store.
  5. Download both the .pfx and .cer file to a folder on the Server. Example: C:\Certs
  6. Close the web browser when finished.
