How to Customize Your Sitecore Connector Using web.config
The web.config file provides the following settings that can be changed:
- SqlConnectionTimeout:
- Specifies the connection timeout in seconds for each request to the SQL server.
- Default value: 30.
- Specifies the command timeout in seconds for each request to the SQL server.
- Default value: 60.
- CredentialsCacheAuthType:
- Specify the authentication type when the Connector is configured to use Windows Authentications for REST API requests.
- Default value is "Negotiate."
- HttpRequestTimeout:
- Specifies the timeout in seconds for each request to the REST API.
- Default value: 100.
- IngoreCertificateValidation:
- Set to "true" if you want to bypass the server certificate validation when making REST API requests.
- Default value: "false."
- DefaultExtension:
- If no extension property is retrieved for an item, this value will be used as a default.
- Default value: "html"
The values for the following properties are constant for the supported versions of Sitecore and for each Sitecore instance.
- RootFolderID
- RootTemplateID
- StandardTemplateId
These values are changed only as part of:
- Debugging
- Troubleshooting
- As part of changes to the Sitecore databases after performing an upgrade.
