Documentum Connector v2 Prerequisites
| Required Permission | Description |
| Documentum User account | A valid Documentum account with READ access to all documents. |
| Documentum version | Minimum version: v6 | EMC Documentum Connector supports all Documentum versions from v6 up. Connects to Documentum DFC via DFC. |
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes | All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework |
| Required Software |
You must install one of the following Java instances before you run the connector installation (.msi file), or your installation could fail.
