Egnyte Connector Prerequisites
The following tables details the requirements that must be satisfied to use the Egnyte connector:
| Required Permission | Description |
| Egnyte User Account |
Admin user account to access with access to all content to be indexed |
| Custom Security | Custom security can be set within the Connector Framework or ConnectivityHub based on business rules. |
| Searchable Content Types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes | The content can be secured via Active Directory domain users and groups or native security |
| Required Software | .NET Framework v4.7.2 |
IIS
- Egnyte requires oAuth 2.0 Standard authentication
- oAuth authentication requires your Egnyte Connector site in IIS be run with HTTPS
Certificates
A domain certificate or a self-signed high trust certificate is required to bind the Egnyte IIS site to HTTPS.
Note
The Egnyte Connector has tools which can help with creating Self-Signed Certificates.
If you decide to use the built-in tools to create a self-signed certificate when installing the connector, then use a service account with local admin permissions.
Application
Before you can use the Egnyte Connector, the end user must have a registered application account.
- With the application you are assigned a private key and secret which is used to access the content to be indexed.
- For oAuth the application requires a redirect page in the following format:
- https://<yourfinalhostname>/oAuth.aspx
Performance
When initially provisioned, Egnyte applications have the following default settings:
- QPS (Queries per Second): 2
- Daily call limit: 1000 calls
To crawl Egnyte content efficiently these numbers must be increased.
Contact your Egnyte representitive to increase the values of these settings.
