IBM Notes Connector Prerequisites
This section details the IBM Notes Connector prerequisites.
This section assumes the reader has considerable knowledge and experience in the configuration and administration of the following programs:
- IBM Notes client versions 8.0 to 10
IBM Domino servers versions 8.0 to 10
| Required Permission | Description |
| IBM Notes User Account |
The Notes client should be configured in "single user mode". Specify which user account you will use when configuring Notes for "single user mode." |
| IBM Notes Client/Domino Servers versions |
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework. |
| Required Software |
IBM Notes Client Microsoft Visual C++ Redistributable (x86) .NET Framework v4.7.2 |
