Nuxeo Connector Prerequisites
Required Permission Description
Nuxeo Account
OAuth based authentication:
  • The Nuxeo Administrator login name and password is required to configure the connector.
  • The Nuxeo connector uses that Administrator account only once to register itself in Nuxeo as an external application, and receive an authentication token.
  • The authentication token is stored in an encrypted way and used to authenticate during crawls.
Basic Authentication:
  • Nuxeo Administrator login name and password is needed. Connector uses these credentials to authneticate.
Features Supported Additional Information
Nuxeo version
Searchable content types All built-in and custom document types. In case of versionable content types the latest version is processed only.
Content Update Full only
Item level security  Yes
Permission Types Yes All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework.
Required Software .NET Framework v4.7.2
