How to Set Up and Configure the Foundation Connector
All BA Insight connectors can be downloaded from Right Answers under Knowledge > BA Insight > Product Downloads > Connectors.
Please review and comply with the Connector Prerequisites before installing.
Install the connector using the installation wizard.
DataSet Connection
The Foundation Connector can create individual datasets for for 3 item types: Matters, Clients, People.
Each item type has a separate .asmx file. The default DataConnector.asmx will be used to index Matters.
To create a DataSet Connection navigate to Connectivity Hub → Datasets → DataSet Connections→ New → Web Service Dataset Connection
When creating a new connection use the appropriate .asmx file corresponding to the item type that will be indexed.
| Dataset | DataConnector file to use |
| Matters | DataConnector.asmx |
| Clients | DataSetConnectorClients.asmx |
| People | DataSetConnectorPeople.asmx |
Connection Info
After you complete the basic settings for this Web Service Dataset Connector, navigate to the General Settings tab
Setting |
Required |
Description |
Login |
Yes |
Enter a Foundation email account with Admin access |
| Password | Yes | The Foundation API key created during Prerequisites |
| API Key name | Yes | The name of the previously created API key |
| Base Url | Yes | The base url used for API calls. The url must be in the format https://{firmname}.foundationsg.com/ |
| Additional properties | No |
If you wish to index additional metadata that is not part of the out-of-the-box metadata. Add the json paths for the new metadata, one on each line. You will need to use the foundation response json structure to obtain the correct json paths. |
DataSet
Datasets → New → Web Service Dataset
The default DataSet configuration is the same accross all 3 DataSets. The only difference is in the properties field.
Properties - a comma separated list of properties that will be used when mapping a webservice Connector to the Dataset.
You must use at least one of the specified properties.
| Dataset | Properties |
| Matters | Id,MatterNumber,SourceRecordId |
| Clients | Id,Number |
| People | Id,Email,SourceRecordId |
Metadata
Each DataSet comes with a number of out of the box metadata.
Go to DataSet → Actions → Metadata → Generate to generate the metadata properties for the selected Dataset.
Custom Foundation Fieldsis supported and properties are created when generating metadata.
If Additional Properties are configured in he Dataset Conneciton, the corresponding metadata needs to be created manually.
On the Dataset Metadata page click New → Text Metadata
| Field | Description |
| Title | The display name of the metadata |
| Value |
Select the Define by Template option Add the json path used in the Connection Config between "[]" [jsonPath] Array json path If your jason path is an array value replace the inner "[ ]" with "_". This change should only be done in the Metadata page and not in the "Additional Properties" field in the connection. Example: languages[0].name becomes languages_0_.name |
Configurable metadata
Availability settings for Clients and Matters have configurable values via the Foundation UI. To reflect these values you must modify the connector web.config file.
The web.config file contains 3 sutom config sections:
- matterConfig - for Matter Availability settings
- clientConfig - for Client Availability settings
- restrictionsConfig - for Use Restrictions
Below are the default values.
<matterConfig> <availabilityTypes> <availabilityType key="0" name="Unspecified" /> <availabilityType key="1" name="Available For Marketing" /> <availabilityType key="2" name="Available With Restrictions" /> <availabilityType key="4" name="For Internal Use Only" /> </availabilityTypes> </matterConfig> <clientConfig> <clientAvailabilityTypes> <availabilityType key="0" name="Unspecified" /> <availabilityType key="1" name="Available" /> <availabilityType key="2" name="Available With Restrictions" /> <availabilityType key="4" name="Do Not Reference" /> </clientAvailabilityTypes> </clientConfig> <restrictionsConfig> <useRestrictions> <restriction key="0" name="None" /> <restriction key="1" name="Do not disclose client name" /> <restriction key="2" name="Do not disclose financial information" /> <restriction key="4" name="Contact Responsible Lawyer prior to use" /> <restriction key="8" name="Do not publish on website" /> <restriction key="16" name="Do not use in submissions" /> <restriction key="32" name="Lawyer Bio Use Only" /> <restriction key="256" name="Do not use client logo" /> </useRestrictions> </restrictionsConfig>
If the setting names are modified in Foundation the "name" field must be manually edited to reflect it's most recent value.
Matter Availability Settings are found under matterConfig → availabilityTypes → availabilityType
Client Availability Settings are found under clientConfig → clientAvailabilityTypes → availabilityType
Example on how to edit Matter availability settings:
- In Foundation "For Internal Use Only" Matter availability was changed to "Only For Development"
- In the web.config file change the line <availabilityType key="4" name="For Internal Use Only" /> to <availabilityType key="4" name="Only For Development" />
- Do not change the key values
The same logic can be used to update Client Availability settings.
Restrictions are common between Client and Matters. Their values can be found under restrictionsConfig → useRestrictions → restriction
You can add up to 12 restrictions to Foundation.
To add additional restrictions to the web.config file go to restrictionsConfig→ useRestrictions and add a new <restriction key="" name=""/> tag.
| Attribute | Value |
| key |
The internal Foundation ID of the Restriction. Use one of the following key values 0 ,1, 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024, 2408 |
| name |
The name of the Restriction |
