SharePoint Online Connector Prerequisites
For the authentication mechanism-specific requirements, see the following pages:
FeaturesSupportedAdditional Information
SharePoint versionOnlineCloud-based
Searchable Content TypesYes
The SharePoint Online connector enables:
  • Connecting to SharePoint Online
  • Fetching data from any:
    • site
    • document library
    • list
      • Indexing this content securely
By default the connector omits some system level properties typically not needed for indexing purpose.
  • If you want to change the list of omitted properties:
    • Edit the Connector's web.config file to specify which properties should be returned.
Content UpdateFull and IncrementalAll BA Insight Connectors support both Full and Incremental crawls, unless noted.
Permission TypesYes
All BA Insight Connectors support fetch ACLs from the source system.
To make items public or restricted to a single user or set of users, you can do so within the Connector Framework.
Required Software
.NET Framework v4.7.2
SharePoint Azure App
Certificate
A SharePoint Online Azure App must be registered with Azure and must have permissions as described in the table below.
See "How to Verify SharePoint Connector Azure API Permissions" to add permissions to the registered app.
Certificate Details:
  • A certificate is required
  • The SharePoint Online Connector supports certificate authentication only
  • Self-signed certificates may be used
Required PermissionDescription
Azure
You must have access to the Azure Portal site and permission to create and manage Azure app registrations.
Azure App permissions
The SharePoint Online connector supports both authentication mechanisms:
The permissions required for each mechanism is detailed bellow.
Windows
The account used to run the connector:
  • Must be a local Administratoron the server.
  • Cannot be any of the built-in service accounts (NetworkService,local machine, etc.)
Recommendations: Loading Users and Groups
When indexing a tenancy containing thousands of site collections, BA Insight recommends using a master security connection to load all users and groups for all site collections in tenancy into a single master security map.
You can then create specific connections to split all the site collections to index into more manageable pieces and reference the master security map for users and groups.
