Teams Connector Prerequisites
Required Permission Description
Azure The installation user account must be able to register, configure and grant Access for an Azure application.
Azure App Permissions
The application configured for the connector must have the following Graph API permissions granted in Microsoft Azure:
  • ChannelMessage.Read.All
  • Directory.Read.All
  • Group.Read.All
  • Member.Read.Hidden
  • User.Read.All
Also, the application should be granted to use Microsoft Teams Protected API on the tenant.
This is a manual process which is described in this article: https://docs.microsoft.com/en-us/graph/teams-protected-apis
The process may take up to a week.
Windows  The account used to run the connector must be a local Administrator on the server and cannot be any of the built-in service accounts (NetworkService,local machine, etc.)
Features Supported Additional Information
Teams version
Searchable content types Yes All content types.
Content Update Full and Incremental All BA Insight Connectors support both Full and Incremental crawls, unless noted.
Permission Types Yes All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework.
Required Software
IIS
.NET Framework v4.7.2
ASP.Net must be enabled
