Troubleshooting OneDrive Connector
The OneDrive Connectorhas a custom log in the Logs folders under the installation target location. By default, the logging level is set to INFO. If you want to troubleshoot, set the log level to DEBUG in the Logging.config file in the installation directory.
The OneDrive Connector does not retrieve 'hidden' properties for the items crawled. If there are properties which you want to include from this category, they must be listed in web.config under "ListOfHiddenColumnsToInclude". A complete record of the 'hidden' properties which have been ignored will be listed in the connector Logs, when setting the Log Level to DEBUG
