Veeva Vault Connector Prerequisites
The Veeva Vault connector enables you to crawl both the full text and metadata of Veeva Vault objects, by querying via the API.
| Required Permission | Description |
| Veeva Vault account |
The account used to crawl your data must have full READ permissions to the following content:
The account used to crawl your data must have DOWNLOAD permissions for either or both of the following (depending on business requirements):
The crawl account must have access to a document's full lifecycle to detect all changes to the document.
Note: The API respects user permissions. If a user does not have permission(s) to a document (VIEW, READ, etc.), then the API does not perform the action requested by the user.
| Veeva Vault version |
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes | All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework. |
| Required Software | .NET Framework v4.7.2 |
