West km Connector Prerequisites
Required Permission Description
Developer Portal Account This account is needed to log-in to Thomson Reuters Developer Portal. (https://developerportal.thomsonreuters.com)
Credentials for connection configuration can be found on this site.
Registered Application for Connector
Authentication of Practical Law Connector is based on the oAuth protocol.
The connector must be registered as an application for the Practical Law Data API prior to installation.
Features Supported Additional Information
Supported versions
Searchable content types yes All content types.
Content Update Full and Incremental All BA Insight Connectors support both Full and Incremental crawls, unless noted.
Permission Types Yes
All BA Insight Connectors support fetch ACLs from the source system.
If you wish to restrict content to specific audiences, you can use the security scripting functionalities present in your connector framework: Connector Framework or ConnectivityHub.
Required Software
.NET Framework v4.7.2
Connectivity Hub
