iManage Connector Prerequisites
Required Permission |
Description |
| iManage User Account | The account used to crawl your items must have full READ permissions to all the content to be indexed from the iManage. |
For security information, see iManage Connector Security.
Features |
Supported |
Additional Information |
| iManage version | +v10 | One installation per iManage tenancy |
| Searchable content types | Yes | The iManage connector enables you to connect to iManage source system, fetch data from any workspace and index this content securely. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user/set of users, you can do so within theConnector Framework. |
| Required Software | .NET Framework v4.7.2 | One installation per iManage tenancy. |
Upgrading from an Earlier Version of the Connector
When upgrading to BA Insight iManage Connector v2.0.0.0-19672 (or later) from an older version (earlier than v2.0.0.0-19672) you must run an index reset and full crawl.
Register a New Application with iManage
Before continuing you need to register your application(s) with iManage.
To register your application(s), open a ticket by sending an email request to appregistration@imanage.com with the following information:
- Application Name
- Provide an appropriate name for your application
- Application Type
- Web App
- OAuth2 Redirect_Url
- http://localhost:2292/oauthresult.aspx
Once your application(s) have been registered, you will receive an email for your ticket indicating that the request has been fulfilled.
Perform the following steps at this point:
- Go to your folder in iManage Share
- Find the document "Technology Partner CloudiManage Credentials"
- Refer to the section which defines the OAuth2 information that your application(s) have been registered with.
- This includes key information such as:
- client_id
- client_secret
- redirect_url
- After you have received notification that your application(s) are registered, enable them in the iManage Control Center (https://cloudimanage.com/imcc) in your developer sandbox.
