How to Configure Pipeline Stages
To configure your pipeline stage, select it from the drop-down menu as shown below.
Note: The description of each pipeline stage is shown below the Pipeline Stage field and changes, depending on the pipeline stage you select.
Available Pipeline Stages
Below is a sample of the many available property mapper stages.
Mapper Stages
Property Mapper:
Translates named property names to that these names map to an existing property on a specific backend.
In order to get results, this stage must be added to both the Query and Results stages.
Refiner Mapper:
Maps backend refinement names and values to match the local refinements.
In order to get the expected results, this pipeline stage must be added to both the Query and Results stages.
Range Facets:
Customize ranges for date, size, and so on.
This pipeline stage must be added to both the Query and Results stages.
SharePoint
SharePoint Online Refiner Mapper:
Maps taxonomies so that the taxonomy labels are displayed and not the GUID.
In order to get results, this stage must be added only as a Results pipeline stage.
SharePoint On-Premise Refiner Mapper:
Maps a backend refinement names and values to match the local refinements.
To get the expected results, this pipeline stage must be added only as a Results pipeline stage.
Scripting/Results Processor
Query Scripting Processor
Query Suggestions Results Processor
Results Scripting Processor
Suggestion Query Processor
Personalized Query: See the How to Personalize User Queries topic.
The stage requires the User Profile to be set.
Debug/Diagnostics Stage
Playback and Recorder stages:
Query Playback
Results Playback
Query Recorder
Results Recorder
