How to Configure Your Similar Documents Component
- Navigate to your SmartHub installation directory.
- Open the sub-folder \modules\SimilarDocuments\.
- Open the file configuration.js in a text editor such as Notepad++ and change the file depending on which type of similar documents requests you want to execute:
Configuration File Components
- ContentBySearchId
- Represents the name of the Content-by-Search component from the Results.html page.
- This setting enables you to configure each component from the search page separately.
- Properties
- The metadata properties (can one or more properties) retrieved from the original results set and used to build the similar documents request.
- Represents which metadata you want to query for similarity between documents.
- TotalNumberOrResults
- The number of results from the original results set that are used to extract the metadata values and build the similar documents requests.
- The documents are prioritized based on the order in which they are returned by the search engine
- PerPropertyValueUsedCount
- The number of unique values used for each metadata from the original results when building the similar documents request
- The metadata values are prioritized based on number of occurrences in the selected results
- ExclusionProperty
- The property that will be used in the similar documents request to filter results that were already returned by the initial query.
- In general it is recommended to use the "clickUri" or document URL because that uniquely identifies a document in a search index.
- This property's values are used to build a negative query along with the similarity search.
- ContentBySearchId
Configuration File Example
Example
Copy
SH.fakeNodeEnvironment();
module.exports = {
Configuration: [
"ContentBySearchId": "SimilarDocumentsComponent",
"Properties": [
"DOCUMENTENTITIES" ],
"TotalNumberOfResults": 10,
"PerPropertyValuesUsedCount": 4,
"ExclusionProperty" : "clickUri" },
"ContentBySearchId": "SimilarDocumentsComponent2",
"Properties": [
"DocumentEntitiesO365", "Department" ],
"TotalNumberOfResults": 2,
"ExclusionProperty" : "clickUri" }]
SH.SimilarDocuments = SH.SimilarDocuments || {}
module.exports = SH.mergeWithExclude(module.exports,
SH.SimilarDocuments.CustomSettings || {},
SH.SimilarDocuments.PathsToExclude || [])
