Similar Documents Scripting Components
There are two built-in pipeline stages that enable pre-processing a similar documents request before executing it in the search engine, as well as post-processing (or even generating) the similar documents results:
  • Similar Documents Query Processor
  • Similar Documents Results Processor
    • Enables processing the similar documents request before sending it to the search engine back-end
    • Usage examples:
      • Block the similar documents request for some of the content by search callers
      • Remove one of the metadata values from the similar documents request if that value is on a specific black list
      • etc.
    • Enables post-processing of the similar results returned by the search engine
      • Can generate similar documents results
        or
      • Query external services
    • Usage examples:
      • Post-process similar documents results metadata
      • Filter results based on specific restrictions
      • Query external services or data sources and inject similar additional similar documents results
      • etc.
