How to Configure the Search Tabs for Content Sources
About
  • The Search Tabs are used to specify which content sources SmartHub uses and how the query changes based on which content source is selected.
  • Search Tabs were initially sourced from Coveo and they are referred to as "CoveoTab" in the BA Insight code.
  • The Search Tabs and the CoveoTab component are one and the same.
  • To configure a Search Tab, edit the HTML page and add the desired attributes to the CoveoTab component.
    See the code and Attributes table below.
Example
Copy
<a class="CoveoTab" data-icon="coveo-sprites-file-small" data-tab-id ="1" data-show-scoped-search-selection="true" data-id="b29924a9-ec32-4c10-8892-a544b69ee121" data-expression='{searchboxquery}
 FederatorBackends:"SmartHubElastic"'
data-caption="Everything"></a>
Attributes
The following attributes are supported:
Setting Default Value Description
data-id
Used to specify the Content Source ID.
This field is required.
data-tab-id
If no data-tab-id is specified the value for the data-id attribute is used.
Used to differentiate between CoveoTab components that use the same data-id attribute. This must be unique for each component.
data-expression
This attribute enables you the alter the query that runs on the page.
In order to target the search box you can use '{searchboxquery}'
data-icon
Used to display an icon next to the caption used for the tab.
data-show-scoped-search-selection false When set to true, the selected CoveoTab is shown in the search box component.
data-caption
The display name used for the CoveoTab.
