How to Configure Your Similar Documents Component
  1. Navigate to your SmartHub installation directory.
  2. Open the sub-folder \modules\SimilarDocuments\.
  3. Open the file configuration.js in a text editor such as Notepad++ and change the file depending on which type of similar documents requests you want to execute:
    Configuration File Components
      • ContentBySearchId
        •  Represents the name of the Content-by-Search component from the Results.html page.
        • This setting enables you to configure each component from the search page separately.
      • Properties
        •  The metadata properties (can one or more properties) retrieved from the original results set and used to build the similar documents request.
        • Represents which metadata you want to query for similarity between documents.
      • TotalNumberOrResults
        •  The number of results from the original results set that are used to extract the metadata values and build the similar documents requests.
        • The documents are prioritized based on the order in which they are returned by the search engine
      • PerPropertyValueUsedCount
        • The number of unique values used for each metadata from the original results when building the similar documents request
        • The metadata values are prioritized based on number of occurrences in the selected results
      • ExclusionProperty
        •  The property that will be used in the similar documents request to filter results that were already returned by the initial query.
        • In general it is recommended to use the "clickUri" or document URL because that uniquely identifies a document in a search index.
        • This property's values are used to build a negative query along with the similarity search.
Configuration File Example
Example
Copy
SH.fakeNodeEnvironment();
module.exports = {
 Configuration: [
 "ContentBySearchId": "SimilarDocumentsComponent",
 "Properties": [
 "DOCUMENTENTITIES" ],
 "TotalNumberOfResults": 10,
 "PerPropertyValuesUsedCount": 4,
 "ExclusionProperty" : "clickUri" },
 "ContentBySearchId": "SimilarDocumentsComponent2",
 "Properties": [
 "DocumentEntitiesO365", "Department" ],
 "TotalNumberOfResults": 2,
 "ExclusionProperty" : "clickUri" }]
 SH.SimilarDocuments = SH.SimilarDocuments || {}
 module.exports = SH.mergeWithExclude(module.exports,
SH.SimilarDocuments.CustomSettings || {},
SH.SimilarDocuments.PathsToExclude || [])
