How To Configure the SearchBox
About SmartHub SearchBox
The SmartHub SearchBox module Enables you to execute queries.
How to Configure the SmartHub SearchBox
To configure the SearchBox component, edit the Custom Settings file that you are using for your SmartHub pages.
For more information about using Custom Settings, seeHow to Customize Your SmartHub User Interface.
  • You can change the SearchBox options by editing the SearchBox code in your custom settings file.
  • You can override any setting by adding it to the SH.SearchBox.CustomSettings namespace.
Example: Out-of-the-box SearchBox Configuration
SH.SearchBox.CustomSettings = {
		"SearchBoxParentSelector":{
			Enabled: true,
			SearchBoxTemplatePath: SH.RootLevelURL + "/modules/SearchBox/templates/searchboxTemplate.html",
			ScopedSearchTemplatePath: SH.RootLevelURL + "/modules/SearchBox/templates/scopedSearchTemplate.html",
			KeepRefinersTemplatePath: SH.RootLevelURL + "/modules/SearchBox/templates/keepRefinersTemplate.html",
			ShowScopedSearch:true,
			ShowKeepRefiners:true,
			RemoveResultsOnClear:true,
			ShowSelectedScope:false,
			EnableDuplicateSearch:true,
			ModuleDetails: {
				SearchBoxPlaceholder: "Search...".toLocaleString(),
				KeepRefinersLabel: "Keep Refiners".toLocaleString()
Make sure that an element with the identifier specified in the SearchBoxParentSelector setting exists on your page;
The SearchBoxParentSelector is also the key used to identify the SearchBox.
The out-of-the-box value for the SmartHub SearchBox is ".sh-search-section".
		".sh-search-section":{
			Enabled: true,
			ModuleDetails: {
SearchBox Settings
SearchBox settings:
Setting
Value
Description
Enabled
Boolean
Default: false
If this is set to "false" the component does not make any changes to SmartHub and doesn't load any dependency
string
Default:
The path to the template used for the SearchBox
string
Default:
The path to the template used for the ScopedSearch verticals
string
Default:
The path to the template used for the KeepRefiners toggle
ShowScopedSearch
Boolean
Default: true
Enables you to show/ hide the ScopedSearch selector
ShowKeepRefiners
Boolean
Default: true
Enables you to show/ hide the KeepRefiners toggle.
If there are no refiners on the page the KeepRefiners toggle will be automatically disabled.
Boolean
Default: true
Enables you to clear the results when you remove the text from the SearchBox
ShowSelectedScope
Boolean
Default: false
Enables you to show/ hide the name of the selected scope
Boolean
Default: true
Enables you to execute multiple queries for the same query text
ModuleDetails
Object
Default:
Contains the labels used in the SearchBox
Component
The SearchBox  has a special container that should be used as a container when showing different components that need to be next to the SearchBox.
That container has the class ".searchbox-widgets" and it should be targeted via the SearchBoxParentSelector.
Example:
".sh-search-section .searchbox-widgets"
Example showing the personalization link:
Exposed Functions and Available Events
Available Events
Event name Trigger Data
SearchboxAdded
Triggered when the SearchBox is created
{SearchBoxKey: key }
