How to Configure the Search Menu
About
The SearchMenu feature is used to navigate between different SmartHub pages.
General Options for the SearchMenu Module
Option Value Description
SearchMenuTemplate
string
Default: SH.RootLevelURL + "/modules/SearchMenu/SearchMenuTemplate.html"
The path to the template used to render the menu
ParentContainerSelector
string
Default: '#menu'
The selector for the parent HTML element.
Items
array
Default:
        'label': "All".toLocaleString(),
        'url': "/Results.html",
        'iconClass': 'fas fa-search',
        'preserveQueryState': true,
        'preserveRefiners': false,
        'preserveQuerySource': false,
        'showTabCount': true,
        'queryTemplate': '{searchboxquery} FederatorBackends:"*"',
        'querySourceId': 'b29924a9-ec32-4c10-8892-a544b69ee121'
The list of menu items
Options for the Menu Items
label
string
Default:  "All".toLocaleString()
The label of the menu item
url
string
Default: "/Results.html"
The URL where the menu item redirects at click
iconClass
string
Default: 'fas fa-search'
The CSS class for the menu item icon
preserveQueryState
boolean
Default: false
Setting it on true preserves the query text and custom attributes when switching menu tabs
preserveRefiners
boolean
Default: false
Setting it on true preserves the applied refiners when switching menu tabs.
PreserverQueryState also needs to be set to true.
Note: This setting is incompatible with showTabCount=true
          The tab count will not take into account any presevered refiner.
preserveQuerySource
boolean
Default: false
Setting it on true preserves the query source when switching tabs.
          The tab count will not take into account any presevered query source.
showTabCount
boolean
Default: false
Setting it on true will show the result counts for the existing menu tabs.
Note: This setting is incompatible with preserveRefiners=true
Note: This setting is incompatible with preserveQuerySource=true
queryTemplate
string
Default: '{searchboxquery} FederatorBackends:"*"'
The query template used on the page specified at the URL setting
querySourceId
string
Default: 'b29924a9-ec32-4c10-8892-a544b69ee121'
The query source id used on the page specified at the URL setting
expertiseConfig
object
The expertise configuration if the page mentioned at the URL setting is an Expertise page.
The expertise configuration and the query template used for expertise pages can be found in the expertise config.js file
The count for the tabs that use Sharepoint Online backends will also contain the duplicate items.
If the admin configured the query template for a page to do XRANK (i.e. ({searchboxquery}) XRANK(cb=100) Author:Jim)  the queryTemplate setting for the tab should not include the XRANK condition.
How to Customize the Template
  1. Duplicate the out-of-the-box, template specified in the SearchMenuTemplate setting:
    1. SH.RootLevelURL + "/modules/SearchMenu/SearchMenuTemplate.html"
  2. Change the SearchMenuTemplate setting to point to the new template.
  3. Customize the copy created at step 1, making sure that the existing HTML structure is kept and the existing CSS classes are still used.
Out-of-the-Box Search Menu Template
Out-of-the-Box SearchMenu Template
Copy
<div class="megamenu">
    <a href="javascript:void(0);" class="menu-header" onclick="SH.SearchMenu.toggleMenu()">
        <div class="menu-header-wrapper">
            <div class="menu-icon-wrapper">
                <span class="menu-icon sh-icon-button">
                    <i class="fas fa-bars"></i>
                </span>
                <span class="menu-header-text" title="Menu">Menu</span>
            </div>
        </div>
    </a>
    <div class="menu-links">
            for(var key =0; key < Items.length; key++){
                var link = SH.SearchMenu.processUrl(Items[key]);
                var label = Items[key].label;
                var itemClass = SH.SearchMenu.isActiveTab(link.toLowerCase()) ? "active" : "";
                var iconClass = Items[key].iconClass;
            <a onclick="SH.SearchMenu.processItem(<%= key %>)" class="<%= itemClass %>" data-tab-index="<%= key %>">
                <span class="menu-icon <%= iconClass %>"></span>
                <span><%= label %></span>
                <% if(Items[key].showTabCount) {%>
                    <span class="menu-count">
                        <span class="loader"><i class="fas fa-sync-alt fa-spin"></i></span>
                        <span class="count">                            (<span class="count-value"></span>)
                        </span>
                    </span>
            </a>
    </div>
</div>
Example of Customized Template
Copy
                </span>
            </div>
        </div>
    </a>
                            <!-- this is the container where the count is rendered. Do not change -->
                            (Results: <span class="count-value"></span>)
                        </span>
                    </span>
            </a>
    </div>
</div>
