Microsoft Search Message
About
Microsoft Search Message backend uses the Graph API to:
- Send search queries to Microsoft 365
- Search for information in email messages (body and attachments)
- Receive emails from user's own mailbox
Set Azure Active Directory Authentication
Set authentication to Azure Active Directory in SmartHub as described here: Azure Active Directory Authentication.
Client ID Requirements
The Client ID specified in Azure Active Directory Authentication above, must belong to an application with the following permissions, set in Azure:
- Azure Active Directory Graph
- User.Read
- Microsoft Graph
- Files.Read
- Files.Read.All
- Mail.Read
- Mail.ReadWrite
How to Add the Microsoft Search Message Backend to SmartHub
Use the following instructions to add the Microsoft Search Message backend to SmartHub:
- Navigate to the SmartHub Administration page:http(s)://[web-app-url]/_admin
- Click Add New Backend.
- The backend dialogue box appears.
- Enter a backend name.
- Select the backend type "MSSearchMessageBackend"
- Authentication
- Impersonate - true
- Security trims the results using the current user running the search
- Impersonate - false
- Client Id:
- Enter the Application ID from Azure App Registrations.
- Client Secret:
- Enter the Key's value from Azure App Registrations.
- Microsoft Login Endpoint:
- Example: https://login.microsoftonline.com
- Access Token:
- Enter the access token from SmartHub's OAuth page.
Refresh Token:
Enter the refresh token from SmartHub's OAuth page.
Note: To get the Access token and Refresh token, the "Authorize" button must be clicked, but it needs all the above fields to be completed (GraphUrl, ClientId, ClientSecret, MicrosoftLoginEndpoint). -
- Client Id:
- Click OK.
If you use SmartHub with Azure Active Directory authentication you can reuse the same App and jump to step 5.
- Navigate to portal.azure.com and log in.
- From the left side menu go to Azure Active Directory → App registrations → New registration
- Name: Enter the name of the application.
- Application type: Select Web app / API.
- Sign-on URL: Enter the SmartHub's URL.
- Select API Permissionsto open the settings menu panel.
- Click Add a Permission.
- Select APIs my organization uses and add the following permissions (as you type the name, it appears):
- User.Read
- Microsoft Graph
- Calendars.Read.All
- Files.Read.All
- Files.ReadWrite.All
- Sites.Read.All
- Sites.ReadWrite.All
- Click Certificates & secrets>New client secret to generate a client secret key.
- In the window that appears (shown below) enter the following information.
- Description:Enter a name for the client secret. (Note: The name is your client secret).
- Expires: Select the period until expires.
- A Value is generated after you clickAdd.
Metadata
BA Insight does this because Microsoft Graph API returns properties in this format:
Example:
"sender":{"emailAddress":{"name":"ExampleName","address":"no-reply@examplename.com"}}}}
In this case, if you want to use property address, you need to add this property in SmartHub: sender.emailAddress.address
Microsoft called this properties "Recipient".
In case that the property from Microsoft Graph API returns a collection of "Recipient", in SH values for the specific property will be returned as string with ";" used as a delimiter.
The format for Recipient collection must be the same as above.
Recipient format is:
propertyName.emailAddress.name / propertyName.emailAddress.addressFind all properties from Microsoft Graph here: https://docs.microsoft.com/en-us/graph/api/resources/message?view=graph-rest-1.0
Example:
In case that the property from Microsoft Graph API returns a collection of "Recipient", in SmartHub values for the specific property will be returned as string with ";" used as a delimiter.
propertyName.emailAddress.name / propertyName.emailAddress.addressHere you can find all properties from Microsoft Graph : https://docs.microsoft.com/en-us/graph/api/resources/message?view=graph-rest-1.0
The following metadata is available for your results:
- @data.type
- summary
- rank
- bccRecipients.emailAddress.address
- bccRecipients.emailAddress.name
- body.content
- body.contentType
- bodyPreview
- categories
- ccRecipients.emailAddress.address
- ccRecipients.emailAddress.name
- changeKey
- conversationId
- conversationIndex
- createdDateTime
- flag
- from.emailAddress.address
- from.emailAddress.name
- hasAttachments
- id
- importance
- inferenceClassification
- internetMessageId
- isDeliveryReceiptRequested
- isDraft
- isRead
- isReadReceiptRequested
- lastModifiedDateTime
- parentFolderId
- receivedDateTime
- replyTo.emailAddress.address
- replyTo.emailAddress.name
- sender.emailAddress.address
- sender.emailAddress.name
- sentDateTime
- subject
- toRecipients.emailAddress.address
- toRecipients.emailAddress.name
- webLink
Limitations
Refiners are not supported by the Microsoft Search Message backend
