Configure Adapter Processing Settings
Adapter Processing settings are generic across all Adapters.
- Select the Adapter Source to configure. Complete the fields shown in the graphic below:
- Enter the Degrees of Parallelism.
- Specifies the number of parallel threads a single Adapter Crawler should use when acquiring content.
- Multiple Degrees of Parallelism by the number of Adapter Crawlers for total threads.
- Enter Batch Processing Size
- The Adapter Crawler processes content in batches.
- In this scenario the Adapter Crawler exclusively retrieves 100 items to crawl.
- The Adapter Crawler does not release these items until each has been crawled, annotated, and published.
- Select Processing Order.
- Once a content source has been enumerated the Adapter Crawler can process these items the Newest First or Oldest First.
- Enter Full Enumeration Cron Schedule.
Enables the end-user the ability to schedule when Full Crawls should execute.
Note: All Cron Schedules follow a specific format which can be found here.
- Enter Incremental Enumeration Cron Schedule
- Enables the end-user the ability to schedule when Incremental Crawls should execute.
- Enter Pause Crawling Cron Schedule
- The Adapter Crawler is a continuous crawler.
- This enables the end-user the ability to schedule when crawling should be paused.
- This is useful when you need to perform maintenance on your Content Sources.
- Enter Resume Crawling Cron Schedule
- Gives the end-user the ability to schedule when paused crawls should resume.
- Continue to configure specific Elastic Adapter settings.
