How to Extract Regex Values From Properties
This component can be used perform Regex value extraction against any available property.
- Output Property:
- Enter the desired output property when values are extracted.
 - Input Property:
- Enter comma separated list of properties or “*” for all properties for regex to be applied against.
 - Pattern:
- Enter any valid Regex Pattern.
 - Return Ordering: Applies to the order of the input properties entered.
- Hit Count:
- Use Hit Count when the desired values returned should be returned by Hit Count.
 - Example: When extracting non-specific matches such as product numbers this would return the product number by how many times the product number match.
- Using Max Values = 1 would return only the value with the most hits.
 - Position:
- Use Position when the desired value returned should be returned by position
 - Example: When extracting non-specific matches such as product numbers this would return the product number in order of how they are matched.
- Using Max Values = 1 would return only the first match value.
 - Max Values:
- Specify the maximum number of unique values to return.
 - Leave empty for all values.
 - Hit Count:
Input Properties
 Depends on the script.
Output Properties
Script
This component can be used to do any kind of processing specified by a script.
The script can be written in C# or VB.NET.
See the topic How to Use Custom Logic (Script) for more details.
Configuration
- The script you use can be used on document content and metadata.
Input Properties:
Output Properties:
