How to Gather More (Related) Data
Datasets
Datasets can be used to get new metadata about documents based on existing ones from an external content source.
Example
- If a database table contains names and email addresses about employees, a dataset can be defined to get the email address of document authors and assign-to-documents.
 - This information can be used after searching to easily reach authors.
Note: Datasets must be defined in Connector Framework.
This component is the only a way to call them from a pipeline.
Configuration
- Select the dataset you want to use.
 - Assign input properties to dataset parameters.
Input Properties
Based on dataset.
Output Properties
Based on dataset.
