How to Record Pipeline Data
Recorder Component
About
  • The recorder component enables the user to record data as it passes through the AutoClassifier Pipeline.
  • All input and output properties generated are captured.
  • This capture output can be re-processed through AutoClassifier for test/debug purposes.
  • Multiple recorders can be used to capture properties at different stages of the pipeline.
  • The data captured for any recorder occurs at the point in the pipeline executed just before the recorder stage.
Configuration
