Configure Online Add-In App Package
Note: This step only applies when using the High Trust Security Model
Procedure:
Expand the app Add-In Package option and specify the following:
  1. App Title:
    1. This has been pre-populated from the Certificate Friendly Name.
  2. App Client Id:
    1. This has been pre-populate and is the same as Issuer ID.
    2. This value must be used when registering the SharePoint Add-In App
  3. Select App Package:
    Choose between:
    1. Classic:
      1. This is SharePoint Classic UI
    2. Modern:
      1. This is the SharePoint Modern UI
    3. Search Tags:
      1. This is a minimal UI without Menu Options
  4. Package the App. This packaged Add-In App is loaded into SharePoint in later documentation topics.
  5. Copy the download to a different location, if desired.
  6. Continue to the next topic.
