How to Configure Components
AutoClassifier Features (Components) integrate the taxonomies that you create into AutoClassifier by creating metadata for input properties based on the taxonomy and rules that you define.
These output properties can then be used by other components or these properties can be stored in the index along with the document content.
Configuration
To configure the AutoClassifier Component, follow these steps:
- Add the Component.
- Existing Components: Click the named link for this component to see the Configuration section:
- Override Input Properties:
- Specify the input properties that pass all of the available properties unless other properties are specified.
- This enables the end user to apply AutoClassifier tagging to specific content.
- Taxonomy Restrictions:
- Specify the taxonomies that are used in order to limit the applied tags (which you separate using semicolons [
- Output Property Name:
- Specify the name of the output property based on your AutoClassifier configuration.
- Field Type:
- Use the down arrow to select the type of field.
- Filters:
- Specify.
- Add:
- Click to add your property.
- Apply:
- Click the Apply button.
Minimum Override Input Properties
| Property | Type |
OriginalPath |
Text |
Output Properties: Based on AutoClassifier configuration.
