How to Clean Up HTML Markup
About
The HTML Markup Cleaner pipeline stage removes HTML tags from the configured metadata properties. When a metadata values contains HTML tags, they are automatically removed and only the inner text is preserved.
How to Add HTML Markup Cleaner to AutoClassifier
- Navigate to the AutoClassifier Pipelines component page:
- Click New Component and select HTML Markup Cleaner from the component list:
- Name your new component and click Add
- Click Apply to save your changes.
How to Configure the HTML Markup Cleaner Component
- Open your HTML Markup Cleaner filtering component.
- In the field Metadata properties to process, enter the list of properties you want to remove the HTML tags from, separated by a semicolon ";".
- Click Apply.
