Configuring the SharePoint Online Add-In
SharePoint Online Add-in Network Requirements
External Communication
  • HTTPS access to the AutoClassifier O365 Add-in service
    • Must be accessible from a location external to the network
    • Must have a valid SSL certificate
  • SharePoint Online
    • The RemoteEventReceiver.svc endpoint is required for SharePoint O365 in-place tagging (annotation)
Info: Traffic for incoming requests
  • From SharePoint O365 credential and payload information in the form of a JSON token is passed to the AutoClassifier add-in
  • AutoClassifier must validate the JSON token for communication between AutoClassifier and SharePoint O365 to be successful
  • For more information, see Microsoft's documentation: When is OAuth used?
Block endpoint: You may block the RemoteEventReceiver.svc endpoint if you are not using AutoClassifier for SharePoint O365
Launch the Add-in Site for Configuration
Info
When using HTTP on a server such as Azure and the server is not attached to a domain, you may need to enable Anonymous access to the site under the Authentication feature.
  1. Launch the Add-In website by using the browser.
    1. Example: https://addin.yourdomain.local
    2. Alternatively, you can browse the website from IIS.
      See the graphic below:
  2. The Add-In Site automatically opens to the Configuration page.
  3. Continue to the next step.
