Configuring the SharePoint Online Add-In
SharePoint Online Add-in Network Requirements
External Communication
HTTPS access to the AutoClassifier O365 Add-in service
Must be accessible from a location external to the network
Must have a valid SSL certificate
SharePoint Online
The RemoteEventReceiver.svc endpoint is required for SharePoint O365 in-place tagging (annotation)
From SharePoint O365 credential and payload information in the form of a JSON token is passed to the AutoClassifier add-in
AutoClassifier must validate the JSON token for communication between AutoClassifier and SharePoint O365 to be successful
For more information, see Microsoft's documentation: When is OAuth used?
Launch the Add-in Site for Configuration
Info
When using HTTP on a server such as Azure and the server is not attached to a domain, you may need to enable Anonymous access to the site under the Authentication feature.
- Launch the Add-In website by using the browser.
- Example: https://addin.yourdomain.local
- Alternatively, you can browse the website from IIS.
See the graphic below:
- The Add-In Site automatically opens to the Configuration page.
- Continue to the next step.
Limitations
Note the following limitations with the SharePoint add-in:
When creating lookup columns on a list or library, Microsoft limits you to a maximum of 12 lookup columns. If the lookup column count exceeds 12 columns, annotating the columns will fail with the following error: "Something went wrong. The query cannot be completed because the number of lookup columns it contains exceeds the lookup column threshold".
If any SharePoint list or library has more than 12 lookup columns, you must choose the columns to be annotated. To specify the columns to be annotated, do the following:
Open the web.config file of the SharePoint Add-in in a text editor.
Add the column names that you wish to annotate to the <add key="SharePointFieldsToAnnotate" value="" /> app setting. The column names must be the internal names of the fields and must be delimited by a semi colon. For example, <add key="SharePointFieldsToAnnotate" value="Prop1;prop2;prop3" />.
If the value parameter is empty, SharePoint will attempt to annotate all the columns.
