Security Scripts and Functions
TargetDirectory Object
Functions Supported by All Target Directories
Function | Input Parameters (Type) | Return Type | Description |
GetUserByDisplayIdentifier()
ByVal displayIdentifier (String) | IUser |
Gets a user from the configured target directory by a user-friendly identifier used on the administration UI as well as show users. If the user is not found, then the null value is returned. |
GetUserByInternalIdentifier()
ByVal internalIdentifier (String) | IUser |
Gets a user from the configured target directory by an internal identifier (GUID, SID, etc). If the user is not found, then the null value is returned. |
GetGroupByDisplayIdentifier()
ByVal displayIdentifier (String) | IGroup |
Gets a group from the configured target directory by a user-friendly identifier used on the administration UI as well to show users. If the user is not found, then the null value is returned. |
GetGroupByInternalIdentifier()
ByVal internalIdentifier (String) | IGroup |
Gets a group from the configured target directory by an internal identifier (GUID, SID, etc). If the user is not found, then the null value is returned. |
Functions Supported by Active Directory
GetUserBySID()
ByVal sid (String) | ADUser | Gets a user by SID. If the user is not found, then the null value is returned. |
GetUserByName()
ByVal name (String) | ADUser |
Gets a user by name in 'netbiosname\username' or 'username@domain' format. If the user is not found, then the null value is returned. |
GetUserByEmailAddress()
ByVal emailAddress (String) | ADUser | Gets a user by email address. If the user is not found, then the null value is returned. |
GetUserByAttribute()
ByVal attribute (String), ByVal value(String) |
ADUser | Gets a user by the specified attribute and value. If the user is not found, then the null value is returned. |
GetGroupBySID()
ByVal sid (String) | ADGroup | Gets a group by SID. If the group is not found, then the null value is returned. |
GetGroupByName()
ByVal name (String) | ADGroup |
Gets a group by name in 'netbiosname\username' or 'username@domain' format. (Only full domain name like 'mydomain.local' is supported.) If the group is not found, then the null value is returned. |
GetGroupByDistinguishedName()
ByVal distinguishedName (String) | ADGroup |
Gets a group by distinguishedName. If the group is not found, then the null value is returned. |
GetGroupByAttribute()
ADGroup | Gets a group by the specified attribute and value. If the group is not found, then the null value is returned. |
Functions Supported by Azure Active Directory
GetUserByID()
ByVal id (String) | AADUser |
Gets a user by Azure Active Directory ID. If the user is not found, then the null value is returned. |
GetUserByUPN()
ByVal upn (String) | AADUser |
Gets a user by userPrincipalName in 'username@domain.onmicrosoft.com' format. (Only full domain name like 'mydomain.local' is supported.) If the user is not found, then the null value is returned. |
GetUserByName()
ByVal name (String) | AADUser |
Gets a user by display name. If the user is not found, then the null value is returned. |
ByVal emailAddress (String) | AADUser |
AADUser |
Gets a user by the specified attribute and value. If the user is not found, then the null value is returned. The specified attribute must also be added to the properties to load text box on the Target Directory Configuration page |
GetGroupByID()
ByVal id (String) | AADGroup | Gets a group by Azure Active Directory ID. If the group is not found, then the null value is returned. |
GetGroupByEmail()
ByVal emailAddress (String) | AADGroup | Gets a group by email address. If the group is not found, then the null value is returned. |
AADGroup | Gets a group by the specified attribute and value. If the group is not found, then the null value is returned. The specified attribute must also be added to the properties to load text box on the Target Directory Configuration page |
User and Group Objects
Properties Supported by All Target Directories
Property | Type | Description |
DisplayIdentifier
String | A user-friendly identifier which is used to display the user or group on the administration UI. (Its format depends on the configured target directory.) |
InternalIdentifier
String | An internal identifier what is typically used to store in ACLs inside the search index. (Its format depends on the configured target directory.) |
Disabled
Boolean | Indicated that the user or group is disabled in the target directory. |
Properties Supported by Active Directory
SID
String | Active Directory specific security identifier. |
Name
String | Name in 'domain\user' format. |
DistinguishedName
String | LDAP specific identifier. |
Properties Supported by Azure Active Directory
ID
String | Azure Active Directory specific security identifier. |
Mail
String | User/Group email address. |
DisplayName
String | User/Group display name. |
OnPremisesSecurityIdentifier
String | The SID of a user/group synchronized with On-Premise AD. |
AdditionalAttributes
Dictionary<String, object> | A list of additional properties loaded for a user/group during the request. The additional properties must be specified in the Azure Active Directory Target configuration page in the 'Properties to load' text box. |
DeletedDateTime
DateTime | AAD Group only: Specifies the date the group was deleted. |
UserPrincipalName
String | AAD User only: Specifies the user principal name. |
HOST Object
User and Group Mapping Functions
Following table contains all the security mapping related functions o the HOST object:
GetSystemId()
String | Gets the unique identifier of user or group returned by connector. |
GetSystemName()
String | Gets the name of user or group returned by connector from the source system. |
GetTargetDirectoryId()
String | Gets the target directory specific identifier returned by connector. |
GetValue()
ByVal key (String) | String | Gets a custom property of the user or group returned by the connector. |
RemapBySystemName()
String | Re-maps the current group to an existing group. This is a group load-only feature. |
GetSystemActive()
Boolean | Gets the "active" status. |
SetSystemActive()
ByVal (Boolean) |
Sets the "active" status. |
GetCount()
Integer | Returns the index of current user or group. |
Access Control Scripts and Functions
Function | Input Parameters (Type) | Return (Type) | Description |
GetSecDesc()
Byte() |
Returns the security descriptor. |
SetSecDesc()
ByVal sd (Byte()) | Sets the security descriptor. | |
CheckIsPublic()
Boolean |
Gets the item Public status. |
SetIsPublic()
ByVal iPublic (Boolean) | Sets the item Public status. | |
AddGroup()
ByVal id (String) ByVal lvl (Integer) ByVal grant (Boolean) |
Adds a group by system ID or target directory ID for multi-level security. | |
AddGroup()
ByVal id (String) ByVal grant (Boolean) |
Adds a group by system ID or target directory ID. | |
AddUser()
Adds a user by system ID or target directory ID. | |
AddUser()
RemoveGroup()
Removes a group by system ID or target directory ID for multi-level security. | ||
RemoveUser()
Removes a user by system ID or target directory ID for multi-level security. | ||
RemoveGroup()
Removes a group by system ID or target directory ID. | |
RemoveUser()
Removes a user by system ID or target directory ID. | ||
Clears all users/groups access. | |
GetGrantGroupIDs()
String() |
Granted groups IDs. |
Granted users IDs. | ||
Denied groups IDs. | ||
GetDenyUserIDs()
Denied users IDs. |
