Azure Cognitive Search Prerequisites
Satisfy all the prerequisites listed on the page Prerequisites before continuing.
- Some search engines such as Azure Cognitive Search only accept plain text data when indexing content.
- For these search engines, Connectivity Hub can use the Tika Text Extraction Service to extract the plain text and submit it to the search engine in lieu of the original document.
The Tika Text Extraction Service installation instructions are here: Install the BA Insight Tika Text Extraction service.
Note: In Connectivity Hub, there is one index created per content source for both Elasticsearch and Azure Cognitive Search.
The search index is populated when you perform your first target sync in Connectivity Hub.
