How to Install and Configure Solr Search
How to Set up Solr
Use the following instructions to set up Solr:
  1. Go to "Targets" tab in the Connectivity Hub header navigation.
  2. Click "New" to create a new target (edit to select an existing target).
  3. The Load Target page appears. Select Solr Target from the drop-down list.
  4. Enter the Target title in the Title field.
  5. Select the Content source from the drop-down menu.
  6. Select the General Settings tab and enter the appropriate information. See the following graphic for examples.
Tip: Text extraction:
For better performance, use a CEWS component like the Tika CEWS service or AutoClassifier to extract the text from item raw data.
Authentication
You set your authentication during the Solr installation and setup.
  • For example, Active Directory,
How to Test Your Solr Installation
  1. To test, using Solr, run a query.
  2. If the query is successful, your installation is successful.
  3. If the query fails, check the installation log for details.
Solr Security
It uses native security.
Use the Advance security module pipeline stage within SmartHub to secure your results at search time.
