Security Scripts and Functions
TargetDirectory Object
Functions Supported by All Target Directories
Function Input Parameters (Type) Return (Type) Description
GetUserByDisplayIdentifier() ByVal displayIdentifier (String) IUser
  • Retrieves a user from the configured target directory by a user-friendly identifier used on the administration UI as well as show users
  • If the user is not found, then the null value is returned
GetUserByInternalIdentifier() ByVal internalIdentifier (String)
  • Retrieves a user from the configured target directory by an internal identifier (GUID, SID, etc)
GetGroupByDisplayIdentifier() ByVal displayIdentifier (String) IGroup
  • Retrieves a group from the configured target directory by a user-friendly identifier used on the administration UI as well to show users
GetGroupByInternalIdentifier() ByVal internalIdentifier (String)
  • Retrieves a group from the configured target directory by an internal identifier (GUID, SID, etc)
Functions Supported by Active Directory
GetGroupByAttribute()
ByVal attribute (String)
ByVal value (String)
ADGroup
  • Retrieves a group by the specified attribute and value
  • If the group is not found, then the null value is returned
GetGroupByDistinguishedName() ByVal distinguishedName (String)
  • Retrieves a group by distinguishedName
GetGroupByName() ByVal name (String)
  • Retrieves a group by name in either format:
    • 'netbiosname\username'
    • 'username@domain'
      • Only the full domain name like 'mydomain.local' is supported
GetGroupBySID() ByVal sid (String)
  • Retrieves a group by SID
GetUserByAttribute()
ADUser
  • Retrieves a user by the specified attribute and value.
GetUserByEmailAddress() ByVal emailAddress (String)
  • Retrieves a user by email address
GetUserByName() ByVal name (String)
  • Retrieves a user by name in either format:
    • 'username@domain'
GetUserBySID() ByVal sid (String)
  • Retrieves a user by SID
Functions Supported by Azure Active Directory
AADGroup
  • The specified attribute must also be added to the properties to load text box on the Target Directory Configuration page
GetGroupByEmail() ByVal emailAddress (String)
  • Retrieves a group by email address
GetGroupByID() ByVal id (String)
  • Retrieves a group by Azure Active Directory ID
AADUser
  • If the user is not found, then the null value is returned.
  • Retrieves a user by email address.
GetUserByID() ByVal id (String)
  • Retrieves a user by Azure Active Directory ID
  • Retrieves a user by display name
GetUserByUPN() ByVal upn (String)
  • Retrieves a user by userPrincipalName in the format:
    • 'username@domain.onmicrosoft.com'
User and Group Objects
Properties Supported by All Target Directories
Property Type Description
Disabled Boolean Indicated that the user or group is disabled in the target directory.
DisplayIdentifier String
  • A user-friendly identifier which is used to display the user or group on the administration UI.
  • Format depends on the configured target directory.
InternalIdentifier
  • An internal identifier what is typically used to store in ACLs inside the search index.
  • (Its format depends on the configured target directory)
Properties Supported by Active Directory
DistinguishedName String LDAP specific identifier.
Name Name in 'domain\user' format.
SID Active Directory specific security identifier.
Properties Supported by Azure Active Directory
AdditionalAttributes Dictionary<String, object>
  • A list of additional properties loaded for a user/group during the request.
  • The additional properties must be specified in the Azure Active Directory Target configuration page in the 'Properties to load' text box.
DeletedDateTime DateTime AAD Group only: Specifies the date the group was deleted.
DisplayName String User/Group display name.
ID Azure Active Directory specific security identifier.
Mail User/Group email address.
OnPremisesSecurityIdentifier The SID of a user/group synchronized with On-Premise active directory.
UserPrincipalName AAD User only: Specifies the user principal name.
HOST Object
User and Group Mapping Functions
The following table contains all the security mapping related functions of the HOST object:
GetCount()
Integer Returns the index of current user or group.
GetSystemActive()
Boolean Retrieves the "active" status.
GetSystemId()
String Retrieves the unique identifier of user or group returned by connector.
GetSystemName()
Retrieves the name of user or group returned by connector from the source system.
GetTargetDirectoryId()
Retrieves the target directory specific identifier returned by connector.
GetValue() ByVal key (String) Retrieves the custom property of the user or group returned by the connector.
RemapBySystemName()
  • Re-maps the current group to an existing group.
  • This is a group load-only feature.
SetSystemActive() ByVal (Boolean)
Sets the "active" status.
Access Control Scripts and Functions
GetSecDesc()
Byte() Returns the security descriptor.
SetSecDesc() ByVal sd (Byte()) Sets the security descriptor.
CheckIsPublic()
Boolean
Retrieves the item Public status.
SetIsPublic() ByVal iPublic (Boolean) Sets the item Public status.
AddUser()
ByVal id (String)
ByVal grant (Boolean)
Adds a user by system ID.
To add the user with granted access, set Grant to true.
To add the user with denied access, set Grant to false.
AddGroup()
Adds a group by system ID.
To add the group with granted access, set Grant to true.
To add the group with denied access, set Grant to false.
AddUser() ByVal id (String)
ByVal lvl (Integer)
Adds a user by system ID to a specific level for multi-level security.
AddGroup()
Adds a group by system ID to a specific level for multi-level security.
RemoveUser()
ByVal id (String)
Removes a user by System ID from the ACL
RemoveGroup() Removes a group by System ID from the ACL
AddTargetUser()
ByVal user (IUser)
Adds a user retrieved from the target directory.
AddTargetUser() ByVal user (IUser) ByVal lvl (Integer) ByVal grant (Boolean) Adds a user retrieved from the target directory to a specific level for multi-level security.
AddTargetGroup() ByVal group (IGroup) ByVal grant (Boolean) Adds a group retrieved from the target directory.
AddTargetGroup() ByVal group (IGroup) ByVal lvl (Integer) ByVal grant (Boolean) Adds a group retrieved from the target directory to a specific level for multi-level security.
ClearAll()
Clears all users/groups access.
GetGrantGroupIDs()
String()
Granted groups IDs.
GetGrantUserIDs()
  String() Granted users IDs.
GetDenyGroupIDs()
  String() Denied groups IDs.
GetDenyUserIDs()   String() Denied users IDs.
