Hardware Requirements, Scaling, and Sizing
Minimum Server Hardware Requirements
BA Insights recommends distributing its applications across two servers:
Following are the minimum hardware specifications required to run BA Insight products.
Servers should be scaled based on:
- Your organization's requirements
- Growth rate of both your:
- Users
- Data required to be indexed
- Users
Server Architecture with BA Insight Products
- Server 1 – Front End
- SmartHub
- Server 2 – Backend
- Connector Backend: Connectivity Hub
- Server 3
- Connectors
- Server 4
- AutoClassifier
Server Requirements
Each server or virtual machine for your web server and database server must have the following general requirements (your specific requirements may vary):
- Processing:
- 4-8 vCPUs
- Memory:
- 8-32 GB RAM.
- NOTE: If you are processsing large videos, BA Insight recommends more memory.
- Storage:
- 1 System Drive (Minimum: 100 GB)
- 1 Data Drive (Minimum: 200 GB)
NOTE: If you are using Elasticsearch, note that it cannot be on the same server as Connectivity Hub.
All INDEXES must be on their own separate INFRASTRUCTURE (VCPUs).
