How to Troubleshoot Your Installation
Use the following log files to troubleshoot:
- Admin site logs:
<Installation Folder>\Admin Site\Logs (typically located here: C:\Program Files\BA Insight\Connectivity Hub\Admin Site\Logs) - Job server logs:
<Installation Folder>\Quartz Server\Logs (typically located here: C:\Program Files\BA Insight\Connectivity Hub\Quartz Server\Logs)
The database connection strings used for the various components are as follows:
- Admin Site configuration file:
<Installation Folder>\Admin Site\web.config- Look for the
ConfigurationDatabaseConnectionStringkey under theappSettingssection.
- Look for the
- Job Service configuration file:
<Installation Folder>\Quartz Server\Bin\Quartz.Server.exe.config- Look for the
quartz.dataSource.default.connectionStringkey under theQuartznode.
- Look for the
