Security Scripts and Functions
TargetDirectory Object
Functions Supported by All Target Directories
| Function | Input Parameters (Type) | Return (Type) | Description |
GetUserByDisplayIdentifier()
ByVal displayIdentifier (String) | IUser |
GetUserByInternalIdentifier()
ByVal internalIdentifier (String) |
GetGroupByDisplayIdentifier()
ByVal displayIdentifier (String) | IGroup |
GetGroupByInternalIdentifier()
Functions Supported by Active Directory
GetGroupByAttribute()
ByVal attribute (String) ByVal value (String) |
ADGroup |
GetGroupByDistinguishedName()
ByVal distinguishedName (String) |
GetGroupByName()
ByVal name (String) |
GetGroupBySID()
ByVal sid (String) |
GetUserByAttribute()
ADUser |
GetUserByEmailAddress()
ByVal emailAddress (String) |
GetUserByName()
GetUserBySID()
Functions Supported by Azure Active Directory
AADGroup |
GetGroupByEmail()
GetGroupByID()
ByVal id (String) |
AADUser |
GetUserByID()
ByVal id (String) |
GetUserByName()
GetUserByUPN()
ByVal upn (String) |
User and Group Objects
Properties Supported by All Target Directories
| Property | Type | Description |
Disabled
Boolean | Indicated that the user or group is disabled in the target directory. |
DisplayIdentifier
String |
InternalIdentifier
Properties Supported by Active Directory
DistinguishedName
String | LDAP specific identifier. |
Name
Name in 'domain\user' format. | |
SID
Active Directory specific security identifier. |
Properties Supported by Azure Active Directory
AdditionalAttributes
Dictionary<String, object> |
DeletedDateTime
DateTime | AAD Group only: Specifies the date the group was deleted. |
DisplayName
String | User/Group display name. |
ID
Azure Active Directory specific security identifier. | |
Mail
User/Group email address. | |
OnPremisesSecurityIdentifier
The SID of a user/group synchronized with On-Premise active directory. | |
UserPrincipalName
AAD User only: Specifies the user principal name. |
HOST Object
User and Group Mapping Functions
The following table contains all the security mapping related functions of the HOST object:
GetCount()
Integer | Returns the index of current user or group. |
GetSystemActive()
Boolean | Retrieves the "active" status. |
GetSystemId()
String | Retrieves the unique identifier of user or group returned by connector. |
GetSystemName()
Retrieves the name of user or group returned by connector from the source system. | |
GetTargetDirectoryId()
Retrieves the target directory specific identifier returned by connector. | |
GetValue()
ByVal key (String) | Retrieves the custom property of the user or group returned by the connector. | |
RemapBySystemName()
SetSystemActive()
ByVal (Boolean) |
Sets the "active" status. |
Access Control Scripts and Functions
GetSecDesc()
Byte() | Returns the security descriptor. |
SetSecDesc()
ByVal sd (Byte()) | Sets the security descriptor. | |
CheckIsPublic()
Boolean |
Retrieves the item Public status. |
SetIsPublic()
ByVal iPublic (Boolean) | Sets the item Public status. | |
AddUser()
ByVal id (String) ByVal grant (Boolean) |
Adds a user by system ID. To add the user with granted access, set Grant to true. To add the user with denied access, set Grant to false. |
AddGroup()
Adds a group by system ID. To add the group with granted access, set Grant to true. To add the group with denied access, set Grant to false. |
AddUser()
ByVal id (String) ByVal lvl (Integer) ByVal grant (Boolean) |
Adds a user by system ID to a specific level for multi-level security. To add the user with granted access, set Grant to true. To add the user with denied access, set Grant to false. |
AddGroup()
Adds a group by system ID to a specific level for multi-level security. To add the group with granted access, set Grant to true. To add the group with denied access, set Grant to false. |
Removes a user by System ID from the ACL | |
RemoveGroup()
Removes a group by System ID from the ACL | ||
ByVal user (IUser) ByVal grant (Boolean) |
Adds a user retrieved from the target directory. | |
AddTargetUser()
ByVal user (IUser) ByVal lvl (Integer) ByVal grant (Boolean) | Adds a user retrieved from the target directory to a specific level for multi-level security. | |
AddTargetGroup()
ByVal group (IGroup) ByVal grant (Boolean) | Adds a group retrieved from the target directory. | |
AddTargetGroup()
ByVal group (IGroup) ByVal lvl (Integer) ByVal grant (Boolean) | Adds a group retrieved from the target directory to a specific level for multi-level security. | |
Clears all users/groups access. | |
GetGrantGroupIDs()
String() |
Granted groups IDs. |
String() | Granted users IDs. | |
String() | Denied groups IDs. | |
GetDenyUserIDs()
String() | Denied users IDs. |
