How to Migrate Connectivity Hub to Another Environment
The following steps outline how you can migrate a Connectivity Hub instance from one environment to another. For example, to migrate a Connectivity Hub instance from a staging environment to a production environment, follow the steps below:
- For each Connectivity Hub server in the source environment:
- Open "Connectivity Hub Web Administration"
- Go to "Configuration."
- Click Leave Farm.
- Copy all the databases from the source environment to the Target environment:
- Configuration databases
- Cache databases
- Install Connectivity Hub on each server in the Target environment.
- After installation is complete, open Connectivity Hub Web Administration.
- Click the Connect To Configuration Database option.
- Connect to the database created in step #2 above.
